Brake light wiring
sasdesignsny
Long Island
Can anyone link me to a thread on here to which is positive and negative for running a load resistor for the LED bulb conversion? ( I mess with oldschool cars so its usually red/black/white or black and black with white stripe) I know this is probably a dumb question but only because I see black with white stripe, black with green stripe and orange with blue and I want to make sure i splice the proper wires for this resistor. Thanks in advance!
Ok, so I found the wiring diag for 2005 LS brake lights ( Brake + is orange/blue) and i figured I would use the neg being black with white) Tried that, and it still threw a error, then tried the black with blue ( last of the three choices) and still it threw a error. I got the LED bulbs from DDM Tuning, the amber directionals in the brake lights work perfectly fine ( obv because it does not need to stay at a constant dim while the parking/headlights switch is on) but I am not too sure how even with a resistor, the issue on the brake lights still occurs. Anyone know or has had this issue?
