brake lines
Jibit
Dearly Departed Friend
Villa Park, IL
anyone know where I can get braided lines? I looking for them on the front. I suppose there are lots of places that I can get them but I don't know the length or anything. Also, I was told that if I upgraded the rear brakes to 13" that I would need to get another line for the e-brake cause the original won't fit. Any suggestions on this?
Go to SCCoA and look for the SS brake line buy thread. Should be in the clasified area as a sticky...
You will only need to change the e-brake cables under the following conditions:
1. Your existing one will not reach the calipers in their new location (unlikely)
2. You change your rear calipers, and the new ones attach to the cables differently
When I switched from stock rear brakes on my 94 Mustang to 13" rears with Camaro calipers, I had to switch the cables because they attached differently.
As far as braided lines go, you would just need a steel braided nylon hi-pressure hose with the correct fittings on both ends.
Paul.
did that but they are selling them in sets, but that's why I contacted classictube.com
