lexdiamondz10304
My ceramic brake pads are brand new and my rotors look fine.. so why are my brakes still squealing?!?!... Can anybody help me out?? It would help alot, Thanks..
lexdiamondz10304 said:My ceramic brake pads are brand new and my rotors look fine.. so why are my brakes still squealing?!?!... Can anybody help me out?? It would help alot, Thanks..
lsbit said:You did at least have the rotors re-surfaced, right? If you didn't, you will probably get noise for at least a while. The pads have to destroy themselves enough to fit the grooves in the rotors you can't see, but while this is happening, the pads get hot and glazed.
It all depends on how badly they're scored (as in grooved, not rated) or warped. The deeper the scoring or more severe the warp, the more material has to be removed during the turning process--if something goes wrong, and you get a really deep groove or bad warp, it's entirely possible that an essentially new rotor will be junk. (It's more likely to be caused by a groove than a warp on modern rotors.)lexdiamondz10304 said:hmm... about how many times can a rotor be cut?... I had them checked, and the brake man said that they might not be able to do them since they are getting kinda thin,..... anyways I took it back to the dealer were I got it from and they are going to replace them... but the car is going to stay in the shop till the 13th.. =(
