Breaking...Hacked emails reveal global warming data was FALSIFIED!
fossten
Louisville
http://hotair.com/archives/2009/11/20/do-hacked-e-mails-show-global-warming-fraud/
To: ray bradley ,mann@[snipped], mhughes@
[snipped]
Subject: Diagram for WMO Statement
Date: Tue, 16 Nov 1999 13:31:15 +0000
Cc: k.briffa@[snipped],t.osborn@[snipped]
Dear Ray, Mike and Malcolm,
Once Tim’s got a diagram here we’ll send that either later today or first thing tomorrow. I’ve just completed Mike’s Nature trick of adding in the real temps to each series for the last 20 years (ie from 1981 onwards) amd [sic] from1961 for Keith’s to hide the decline. Mike’s series got the annual land and marine values while the other two got April-Sept for NH land N of 20N. The latter two are real for 1999, while the estimate for 1999 for NH combined is +0.44C wrt 61-90. The Global estimate for 1999 with data through Oct is +0.35C cf. 0.57 for 1998.
Thanks for the comments, Ray.
Cheers, Phil
Prof. Phil Jones
Climatic Research Unit
To: Phil Jones [...]
Subject: 1940s
Date: Sun, 27 Sep 2009 23:25:38 -0600
Cc: Ben Santer [...]
Phil,
Here are some speculations on correcting SSTs to partly explain the 1940s warming blip. If you look at the attached plot you will see that theland also shows the 1940s blip (as I’m sure you know).
So, if we could reduce the ocean blip by, say, 0.15 degC, then this would be significant for the global mean – but we’d still have to explain the land blip. I’ve chosen 0.15 here deliberately. This still leaves an ocean blip, and i think one needs to have some form of ocean blip to explain the land blip (via either some common forcing, or ocean forcing land, or vice versa, or all of these). When you look at other blips, the land blips are 1.5 to 2 times (roughly) the ocean blips—higher sensitivity plus thermal inertia effects. My 0.15 adjustment leaves things consistent with this, so you can see where I am coming from.
Removing ENSO does not affect this.
It would be good to remove at least part of the 1940s blip, but we are still left with “why the blip”.
Let me go further. If you look at NH vs SH and the aerosol effect (qualitatively or with MAGICC) then with a reduced ocean blip we get continuous warming in the SH, and a cooling in the NH—just as one would expect with mainly NH aerosols.
The other interesting thing is (as Foukal et al. note – from MAGICC) that the 1910-40 warming cannot be solar. The Sun can get at most 10% of this with Wang et al solar, less with Foukal solar. So this may well be NADW, as Sarah and I noted in 1987 (and also Schlesinger later). A reduced SST blip in the 1940s makes the 1910-40 warming larger than the SH (which it currently is not)—but not really enough.
So … why was the SH so cold around 1910? Another SST problem? (SH/NH data also attached.)
This stuff is in a report I am writing for EPRI, so I’d appreciate any comments you (and Ben) might have.
Tom.
To: Michael Mann
Subject: Re: BBC U-turn on climate
Date: Mon, 12 Oct 2009 08:57:37 -0600
Cc: Stephen H Schneider , Myles Allen , peter stott , “Philip D. Jones” , Benjamin Santer , Tom Wigley , Thomas R Karl , Gavin Schmidt , James Hansen , Michael Oppenheimer
Hi all
Well I have my own article on where the heck is global warming ? We are asking that here in Boulder where we have broken records the past two days for the coldest days on record. We had 4 inches of snow. The high the last 2 days was below 30F and the normal is 69F, and it smashed the previous records for these days by 10F. The low was about 18F and also a record low, well below the previous record low.
This is January weather (see the Rockies baseball playoff game was canceled on saturday and then played last night in below freezing weather).
Trenberth, K. E., 2009: An imperative for climate change planning: tracking Earth’s global energy. Current Opinion in Environmental Sustainability, 1, 19-27, doi:10.1016/j.cosust.2009.06.001. [1][PDF] (A PDF of the published version can be obtained from the author.)
The fact is that we can’t account for the lack of warming at the moment and it is a travesty that we can’t. The CERES data published in the August BAMS 09 supplement on 2008 shows there should be even more warming: but the data are surely wrong. Our observing system is inadequate.***
Here are a few more:
At 09:41 AM 2/2/2005, Phil Jones wrote:
Mike, I presume congratulations are in order - so congrats etc !
Just sent loads of station data to Scott. Make sure he documents everything better this time ! And don’t leave stuff lying around on ftp sites - you never know who is trawling them. The two MMs have been after the CRU station data for years. If they ever hear there is a Freedom of Information Act now in the UK, I think I’ll delete the file rather than send to anyone. Does your similar act in the US force you to respond to enquiries within 20 days? - our does ! The UK works on precedents, so the first request will test it.We also have a data protection act, which I will hide behind. Tom Wigley has sent me a worried email when he heard about it - thought people could ask him for his model code. He has retired officially from UEA so he can hide behind that. IPR should be relevant here, but I can see me getting into an argument with someone at UEA who’ll say we must adhere to it !
To: santer1@XXXX
Subject: Re: A quick question
Date: Wed Dec 10 10:14:10 2008
Ben,
Haven’t got a reply from the FOI person here at UEA. So I’m not entirely confident the numbers are correct. One way of checking would be to look on CA, but I’m not doing that. I did get an email from the FOI person here early yesterday to tell me I shouldn’t be deleting emails - unless this was ‘normal’ deleting to keep emails manageable! McIntyre hasn’t paid his £10, so nothing looks likely to happen re his Data Protection Act email.
Anyway requests have been of three types - observational data, paleo data and who made IPCC changes and why. Keith has got all the latter - and there have been at least 4. We made Susan aware of these - all came from David Holland. According to the FOI Commissioner’s Office, IPCC is an international organization, so is above any national FOI. Even if UEA holds anything about IPCC, we are not obliged to pass it on, unless it has anything to do with our core business - and it doesn’t! I’m sounding like Sir Humphrey here!
...If anything, I would like to see the climate change happen, so the science could be proved right, regardless of the consequences. This isn’t being political, it is being selfish.
Cheers, Phil
Email 1182255717.txt
Wei-Chyung and Tom,
The Climate Audit web site has a new thread on the Jones et al. (1990) paper, with lots of quotes from Keenan. So they may not be going to submit something to Albany. Well may be?!?
Just agreed to review a paper by Ren et al. for JGR. This refers to a paper on urbanization effects in China, which may be in press in J. Climate. I say ‘may be’ as Ren isn’t that clear about this in the text, references and responses to earlier reviews. Have requested JGR get a copy a copy of this in order to do the review.In the meantime attaching this paper by Ren et al. on urbanization at two sites in China.Nothing much else to say except:
1. Think I’ve managed to persuade UEA to ignore all further FOIA requests if the people have anything to do with Climate Audit
.2. Had an email from David Jones of BMRC, Melbourne. He said they are ignoring anybody who has dealings with CA, as there are threads on it about Australian sites.
3. CA is in dispute with IPCC (Susan Solomon and Martin Manning) about the availability of the responses to reviewer’s at the various stages of the AR4 drafts. They are most interested here re Ch 6 on paleo.
Cheers
Phil
I showed these emails to a treehugging woman at work. She simply said, well that's unfortunate but that doesn't invalidate AGW.
Denial.
