Markviiiedrea
Speed Bump
I removed my exhaust on Monday for removal of of my transmission and I managed to break the stud off on the right side manifold (lower stud). There is about ¾” inch still sticking up but not enough to thread a nut on to it. The other one is corroded really bad and should also be removed ( but it still works for now)
Opt 1.
I would like to try heating it up and backing it out but my access to a torch is limited and I’m not pay $150 to rent one.
Opt 2.
Cutting them off flush with the bottom of the flange and getting a long drill bit in there to drill them out. That never seems to go my way and I end up having the holes off center.
Opt 3.
Grind a flat on the sides and use a wrench to back it out but that would need some sort of heat source for that to be successful.
Opt. 4
Cut the stud flush and weld a new bolt right on the manifold. I don’t think I'm a good welder to do this plus I would have to barrow one from a friend.
Opt 5.
Remove manifold and install another used one
What do you guys think? What other things have you done to get a broken stud out of the manifold? The transmission will be out of the car here tomorrow and I will have more room. Once this is fixed I can re assemble my car. Sorry about the bad cell phone pictures but that is the best I have.
Thanks
Opt 1.
Opt 2.
Opt 3.
Opt. 4
Opt 5.
Thanks
