frankenstang
im trying to pass off this car I no longer want, ille copy and paste my add from craigslist to save some time but its all still the same.
the price is 2000 firm ONLY ! and it must be picked up from me here in ironwood Michigan,its worth the trip if you have to journey.
Im looking to sell or trade my built Thunderbird,2000$ I have way more than that in this,ille list some prices.i have about 6000 into this car.414-429-6312
the car has:
1997 thunderbird LX , 1500$
Pi heads and PI cams, running 10:1 compression 750$ after rebuild
superchips tuner 250$
edelbrock vic jr intake manifold 350$
high flow oilpump 100$
70mm throttlebody and ported plenum 200$
2.5in dual exhaust with no cats and flowmaster 40series mufflers 500$
73mm calibrated mafs with new style skinnybody 24lb injectors 300$
b&m shiftkit and new valvebody 300$
383 gears in the rear end and a rebuild kit 300$
xenon bodykit, thing is indestructible 1200$
Lots of new parts like alternator,new valves and valve seals when the heads were done.New timing chains timing guides and every gasket from headgaskets on up are new,the trans and rear end was rebuilt when the gears were put in and the trans has a new valvebody not just a shiftkit..
only problems are: clearcote fade on the hood , speedo is 10 off when ur doing 55+ because of the gears .and its a 1997 so there are minor scratches here and there and maby a litttle ding or two.The bodykit was installed because the car was getting the typical mn12 rear rocker rot.
again call text or email 414-429-6312..in trade im looking for another sports car or a truck,im looking to trade my car for something that's really clean.I have a lot into my car mechanically just not looks, if you know anything about bodys wich I don't you can make this one awesome car.Trade value is higher considering all my car has.
the car has:
