Calipers???
87 Linc Basket
Dallas
My rear calipers are leaking major fluid!!! Has anyone experienced this problem, if so how difficult is it to change out calipers?? Holla at cha boy
Not hard but u might want to take it to a shop to insure proper installation. Too much info to type. Try searching around the internet.
Wheres it leaking from.. hoses or the caliper itself.
Easy fix.
skymasteres said:
Make sure you get one of thoes tools to screw the piston into the caliper body if, when you replace it. :)
a C-clamp is the name of the tool.
hi ,,,the callipers are the screw- in type on my 91 : ,,,the c-clamp won,t work :bow: ,,its a good idea to check the hoses before you condeme the callipers and :I ,,,,to look at the entire rear brake system before you start spending your loot ,, :dj: : regards "kahuna" :Beer
The tool looks like this:
Might be able to rent one at Autozone or Advance Auto Parts.
The c-clamp worked ok for me but I bought new calipers anyway. The tool is probably a lot easier. Also try renting one at murray's.
On my 90 the c-clamp will serve just fine for the front calipers . The rears require a tool to turn piston back in to the caliper body. Got a "universal" tool at local parts store, with a 3/8 drive for about $13. Total time for one real caliper -- just over an hour. Good luck. Lincolnlov
