00NORCAL V8
amp and sub help me out with something? I posted before on this and last night I took a test light and determined I was getting constant power to my amp. I see 2 speaker wires, a ground wire and then a yellow/orange wire. I am assuming this is the remote wire? So I tested that wire with key on and I am not getting power from that wire. Am I correct in saying this is the remote wire? Can any of you who have the factory setup go and check to see if that wire gives you a reading that it has power? This would be a big help because it helps narrow down my problem. TIA
