Shaun 97VIII
So i am on my way to work and i come to a stoplight and the engine dies.
All the electronics work, engine turns over but does not start.
From what I saw on the tipminder screen:
Check Trac. Control
Trac. Control Error
Fuel Flow Error
that is what i saw shortly after the engine died. i was more worried with getting the car out of the middle of 3 o clock traffic then seeing what the tripminder says.
after a few moments of fussing around i got the car into neutral and pushed it to the side, called tow truck, its at the shop tonight.
what do you think it is? when the engine turned over it did so very fast, like there was no compression (fuel flow error?) i did not check the schrader valve on the fuel rail since i didnt think about it right away.
thanks guys,
shaun
Check Trac. Control
Trac. Control Error
Fuel Flow Error
thanks guys,
shaun
