Car problems
Honey badger
Port richey
So yesterday when I went out for lunch I made it to the end of my street then I pressed the gas and nothing was happening I proceeded I turn off the road as I was rolling. Steering was gone then brakes were gone ( figured car shut off). The car wouldn't start waited 40 mins car started but sputtered like it wasn't getting enough gas to the engine. Any idea what the problem is? If you know can you tell me the Aprox price.
That sounds to me like a failing fuel pump. Either that or a clogged fuel filter. Sorry, no idea on the price but rockauto is your friend here. Use discount code 112436299214690 through November 18 for a 5 percent discount for parts.
Fuel pump/system fault or bug on the MAF are the two most likely causes for your symptoms.
