Hey everybody, I did search before posting. The closest thread I found similar to my problem is this one :
http://www.lincolnvscadillac.com/forum/archive/index.php/t-85272.html . Unfortunatly the guy didnt have the exactly same problem that I have and therefore that is why I am posting this thread.
Before explaning my problem my LS is a 04 and has the v6 engine. SO, my little ``problem`` is that when I accelerate the rpm will ``block`` just over 2500 rpm and it is only when I push the gas pedal down to certain point that my rpm will go over that 2500 mark. After my rpm has passed 2500 everything is fine though. I don't know if this could be helpfull to find the probable cause of my problem but I noticed that mostly happens when I'm in 5th gear (80km per hour and over / in lower gears I usually go pass the 2500rpm mark without any ``blocks``. I can also say that this ``problem`` happened before and after I changed all of my coils/plugs ( I drove about 5k kilomtre since I changed them). Oh and by the way I don't need to push down my gas pedal all the way down to go over the 2500rpm mark, just push on the gas pedal a little more.
No check engine light on.
Any ideas on what the problem could be ?
