SeaPro
I've got a 2005 LS and am trying to find where the CD changer is located. Any ideas?
Thank you
Thank you
RTFM...
CD changers only came in two locations in the LS, inside the glove box and inside the radio.
... since the CD changer stopped working and the NAV seem archaic compared to even my cell phone.
I didn't think that in the glove box was an option for gen II?
If you are interested, I have the working CD changer from my 06 THX nav that I replaced. (Yes, the CD changer is separately replaceable on the headunit.)
...Is there any pairing that needs to happen with the head unit and CD changer or is it simply plug and play?
You might take a look inside your changer first to see if it is something simple. Mine failed once and it was simple to fix. There is a flat-flex cable in there that had pulled loose. It pulled loose because they had excess glue on the ID label on the cable. This caused it to stick to a moving part of the changer, and this pulled the cable out of one of it's connectors when the moving part moved.
