CD changer
richduty455
South Jersey
I just recently purchesed a 95 mark VIII.....I had the original lincoln cassette player in it, but it looks like the radio is the one for the CD palyer....it had the CD button instead of the dobly button, my question is if I get a factory CD changer for my car is it already wired up for one or do i have to wire everything up? I'd like to keep the stereo stock.
I'm not sure but you could look behind the trunk liner on the driver's side at the back corner of the trunk. If it is wired you should see the wire harness there.
If not it is not hard to install the wire for the CD changer. If you want you can find changers on eBay. My OEM CD changer went bad on my 95 and I replaced it for under $100 with a 12 disc JVC I got on eBay. Works great.
Just make sure that you get the FM modulator with any after market changer and the cable if buying on eBay.
With the aftermarket units you can keep your OEM radio.
If you have any questions on any eBay aftermarket changers PM them to me and I will tell you whether I'd risk bidding on them or not.
I've had some pretty good luck on eBay buying electronics but that doesn't been one still could get screwed.
