If you live close to an AutoZone auto parts store, they will scan your code(s) for free.
i did get a code for the clockspring, but i know there's a code for the passenger seat airbag. However, I'm still wondering if the airbag module data is full. I was in an accident and did have a code that went along the lines of "Crash data full."
Do I have to replace the airbag module (not not talking about the airbag itself) after an accident?
Yes, if you get the crash data full code.
Also note that you must replace all seat belts that were worn during the accident (they stretch one time only), and all seat belt pretensioners (these will turn the light on too).
passenger seat airbag. any way to be sure the pretensioners are ok?
the car was hit on the passenger side front door that resulted in seat airbag to deploy. As far as why the dash airbag along with the others didn't deploy are beyond me.
Okay, then that makes sense. I missed that it was the side air bag. The seat belts and pretensioners should be okay.
I think that you usually have to replace the side impact sensor and safety sensor when this happens.
This is from the service manual
When any deployable device or combination of devices are deployed and/or the restraints control module (RCM) has the diagnostic trouble code (DTC) B1231 (Crash Data Memory Full) in memory, the repair of the vehicle's SRS is to include the removal of all deployed devices and the installation of new deployable devices, the removal and installation of new impact sensors, and the removal and installation of a new restraint control module (RCM).
When any damage to the impact sensor mounting points or mounting hardware has occurred, repair or install new mounting points and mounting hardware as needed.
When the driver air bag module has deployed, a new clockspring must be installed.
Inspect the entire vehicle for damage, including the following components:
Steering column
Instrument panel knee bolsters and mounting points
Instrument panel braces and brackets
Instrument panel and mounting points
Seats and seat mounting points
Safety belts, safety belt buckles and safety belt retractors. For additional information, refer to Section 501-20A
SRS wiring, wiring harnesses and connectors
After carrying out the review and inspection of the entire vehicle for damage, repair or install new components as needed.
Ah, so currently I have full illumination with no blink. So is that safe to assume module replacement is in fact necessary? Based upon that service manual?
[Continuous] [The Air Bag Indicator is Illuminated Continuously, RCM Disconnected or Inoperative, Loss of Battery Feed, or Loss of Signal Ground]
IDK about the LS airbag, but on my rebuilder Chevy Cruze the plugs melted after the bag deployed. I wound up changing the clockspring, but cut and solder plugs are available on eBay.Right on. Thanks for the help. Going to order a new bag and module to go along with my seatbelt.
Is there a chance the ignition of the airbag has melted or destroyed my clockspring? Steering buttons still work, but I read something like the clockspring could melt - but it was only vaguely mentioned.
