I worked on the car whenever I had free time. So added up, it took me about 5 days to reinstall all of the factory air suspension parts. I did fix mine, I fixed it today. After the prosses of elimination, I found that the "new" solid state relay was no good, so I messed around and found a Ford OEM replacement. I'm ridin on air
[/Early bird, Hi, see you found the "ticket"(relay) to ride. I have been reading your posts off and on and thanks for the last reply. Will you help me? I have new air parts from Arnott still in the box . Planned on installing them when I could get the mark to rise up off the graven. All 4 wheels are down with the frame resting on my gravel driveway. Last year I tried to back it out with the compressor not running. Can't get the car to pump enough to drive to a garage or work at my home garage. Planned on "rebirth" of the air ride" 100% new parts. Is there a way to wire direct to the compressor ? Should that not come on then its the compressor and installing the new one can make it come up(if its the compressor. Just putting it in I am not liking because it will be considered used and likely be called a used part . Makes Arnott likely to turn down the return. Knowing if its the compressor the first time eleminates the used compressor situation with Arnott. Again , is there a way to direct connect the compressor and not damage the computer/wiring to car? . Arnott has a 90 day return on unused parts Nice company as they guarantee their air parts for life if they fail and due to a defect. Very professional friendly people and no phone tree as live calls are done with real people. > Arnott tech said she did not know of a way to try bypassing the computer activation and wire direct . I don't really want to convert to springs . Might be my only choice and do them in my garage after somehow jacking up car. Thanks , looking for your ideas. Bill out of Ohio
