Check antilock brakes...
suncoaster
bc
I get this message on my overhead console in my '85 Mark VII. The light is on constantly. My brakes work fine; what's it mean?
I also have a continuous light up there that says "check suspension."
my antilock brake light on my dash was on in my 91 mark VII for the longest time but now it doesnt come on anymore. even when it was on the anti lock brakes worked fine cause i tested them. :confused: i wouldnt worry about it to much?
-Lincolngirl
The amber brake light is a passive alert letting you know that you may have low fluid or low boost or excessive pump usage. The red brake light is related to failures and the car shouldn't be driven. In either case, the brake system needs servicing.
The SYSTEM ON OFF SWITCH (suspension cut out switch) is in the OFF position. Switch it to ON. (click the picture to enlarge it)
also when it sais check anti lock breaks the orange light up high. ur anti lock brakes arent working. because something is wrong the car turns em off.
when that happens to me it means my break fluid is low. but thats because my master cylinder is leaking somewhere. still havent figured out where.
