bird sled
the check engine light came on my 97 lincoln conti "po135" o2 censor.monitors said '3 inc incomplete. ' i put on new o2 sensor on the first bank 1, first one on the exhaust manifold. and cleared code. and now monitors are at "5 inc "incomplete. after i clear the check engine light code. it seems to be going from 3 incomplete monitor to 5 incomplete . and i have to have the cars emissions inspection. what can i do to clear check engine light and still have all the monitors running properly? at least enough monitors allowed to have auto inspection to run test . i believe it is 7 monitors that have to be funtioning before the mechanic can actually run the test here in missouri. please help . thanks again . bird sled. could i have replaced the wrong 02 senser. and i still have problems ???????????
