Hello everyone, it's been a while since I've had time to get on. I have a 2003 Sport V8 with about 68K.
Everything seems to be running normally and well, when I first purchased the car with 61K miles I replaced all 8 coils/plugs with Motorcraft and immediately stopped a mild misfire that was happening.
In the past 4 months, I have gotten about a half dozen warning tones that I would usually associate with a DTC or low fuel level. When I look down at the dash, however, there is no hint of any CEL or description displayed on the message center, and my fuel level was always above half tank. Once, the last time it happened (around a month ago) I happened to be looking at the instrument cluster. I heard the tone, saw a description on the message center for less than one second, but I don't think the CEL ever illuminated.
Upon checking the PCM with my code reader, I found that the code was a P0153 (O2 Sensor Circuit Slow Response) and had freeze frame data, including a MIL status line that read "MIL Status: NOCONV." This code doesn't worry me as much as the CEL not lighting up, as it sounds like a semi-contaminated sensor.
Also, I have noticed that since I've owned the car, the CEL does not light with the system check upon turning the key to the ignition position.
So...what do you guys (and gals) think? Has anyone else had this issue?
Thanks in advance,
-Dan
Thanks in advance,
-Dan
