Check out the latest ebay item...
If I'm not mistaken that is one of the manifolds that Lou tested out for his fit up. Also, I believe that is the Geoff Knight selling that item which made the one Lou is using now.
I have to tell you....from what I can see there, that looks like a VERY poor job. Look how rough the pointed end of the port looks. Kind of looks like they cut it by drilling a bunch of holes in a line!! Maybe I'm not seeing it correctly...
right - this was the second prototype we tried. we 'mocked' it up to test the fit under the hood. We change the design - since the blower's output port mounted directly on top of the manifold (like a stock GM car) but intercooling this would be an issue - the only options were either a 'spray methanol' type, of a thin core rad that goes between the output port and manifold - but the hood clearance was an issue.
The new manifold I have installed lowers the entire unit, has the blower inverted (like the stock SC t-birds), uses the stock SC t-bird inlet/outlet plenums. Much, much better.
There's also an abundance of two tone tailights on there with no wiring or bulbs, someone should get on that.
