check suspension light?
blacknavi
middletown
I am new to the site and need help! I just put new tires on my 98 Navi and the check susp light came as soon as i drove it off the rack and has not yet gone off! I also notice that the rear is a little lower than the front so i assume that the bags aren't doing their job. How can I "check suspension" and remedy this problem?
thanks
branden
turn the key off, and restart the vehicle
that should reactivate the air ride
If not, then they have turned it off via the switch like they were supposed to do before putting it on a lift.
Its been on for a couple days, so where is this switch located and should that turn my air ride back on?
On navi's its usually on the passenger side kick panel. Could also be in the rear of the truck on the left (I think behind a cover)
