Check Tire Pressure Warning on a 2004
KSnav
Olathe, KS
This is the first Nav that I have owned (since Jan 2005).
When 1st driving her each morning now that it is freezing, the Tire Pressure Monitors give me a 2 idot lights (the tire symbol & the "Check Tire Pressure" message on the dash until the old girl is warmed up.
And then they go away.
Has anyone else had this problem?
Of course I have checked the tires & they are all ok.
The only other problem I have had was with the side cladding & the corners bowing out (bad fit).
The dealer took care of it right away & replaced all of them!
So far I'm lovin' my new ride.
Are you checking the tire pressure when the tires are cold? You should be.
