johnnytech
I have a clicking in my F/drive tire/brake. I just had the ball joints and lower contol arm replaced. The mechanic has said it is anti-rattle clips. After 3 trips back to the mechanic the clicking stops for about 10 miles then is back.
I noticed that the rotor is extremly hot (Under normal driving conditions).
Along with the ball joint replacement, I had the rear passenger caliper replaced (leaking , not working properly).
And the final straw. Driving to work this morning (12 miles top speed 45mph) My ABS, Traction Control and Brake light are all on. After stoping shut the car off and restarting the Brake light is off, but the ABS and Traction Control are still on. This is frustrating considering I just dumped a ton into this for the ball joint and caliper.
Any help or suggestions would be appriciated. Thanks.
BTW: My car according to Ford/Lincoln was not under the recall. And that sucks.
