Climate Control Issues
Ozman
Joplin
Recently I have been having some issues with my climate control. Every once in a while, after the car has been running for a while, the passenger side vents will start blowing out hot air. The driver's side always stays very cool, and I always have the controls set at automatic w/ the temp the same on both sides. It seems to be happening more and more often. Sometimes simply turning the system off then back on will reset the problem, but other times, it takes turning the car completely off. If anyone has some advice or experience w/ this problem, let me know. Thanks.
There is quite a bit of information on this. Use the Search button to find more topics but here is one that talks about your problem:
http://www.lincolnvscadillac.com/showthread.php?t=8392&highlight=Climate
have seen a few problems with the duel climate control systems watter control valve screwing up.
I Have An After Market Radio And The Temp Button Is Very Hard To Get To Work Anyhelp????? I Have To Almost Pust It Throught The Dash And The Rear Defrost Doesnt Work When This Happens
I Have An After Market Radio And The Temp Button Is Very Hard To Get To Work Anyhelp????? I Have To Almost Pust It Throught The Dash And The Rear Defrost Doesnt Work When This Happens ITS A 2002 LS AND ONLY WHEN I TRY TO TURN THE HEAT UP
I Have An After Market Radio And The Temp Button Is Very Hard To Get To Work Anyhelp????? I Have To Almost Pust It Throught The Dash And The Rear Defrost Doesnt Work When This Happens ITS A 2002 LS AND ONLY DOES IT WHEN I TURN UP THE HEAT OR TRY TO
Common issue with the climate control. Mine has done it maybe 6 or 7 times. A good hard WOT push for about 2 seconds always fixes or unsticks or whatever is going on, if your not moving give it a good rev. in neutral. Always seems to work and i dont understand the connection. Try it.
