Coil spring conversion questions!
Drew4002
Detroit
I am about to convert my 88 LSC over to coil/springs because my front right bag is leaking. I have a perfect 88 Mustang 5.0 to use for donor parts. I read the tech article on how to do this. I understand it and it dosn't seem too hard but I do have a couple questions. The article says to use lower control arms from a 87-88 T-bird Turbo Coupe. Can I use the lower control arms off of the 88 stang or will they not fit right? Also, is it possible to just eliminate the front air bags and leave the rears in working condition. I will eventually eliminate all of the air bags, but time is a problem right now and I want to at LEAST get the fronts fixed. Plus I like how the rear air bags plant the power to the ground without much tire spin/hop. Any help would be appreciated!
