comp flash reprogram
mcafferty
Lakeville
Where did people get there comp reprogramed? I have a jet chip in my explorer and love it is there anything like this for a 2001 LS V8? how much is it costing and does it void your warrinty? could you get a second comp and do this to and switch them back if you had any problems? how much to the comps cost? thanks much...Mac
you can find local dealers through http://www.sctflash.com/main.php the find a dealer box is in the upper right hand corner or contact Torrie at fordpartsnetwork.com if you do not mind working long distance with some one.
Mr. Torrie R. McPhail - (Owner)
http://www.fordpartsnetwork.com
SCT Custom Chip / Flasher dealer
Dynojet WideBand Commander dealer
Wide Band Dyno tuning services now available
Dyno shop # 904-819-9637
The only issue I see for seeking out a local person to do the tuning is that he/she can observ directly what the reflash is doing. If you can't find a local dealer then you might just want to seek out a dyno shop so you can test the tune and send the results to Torrie. Other than that from what I observed it is something anyone can do at home once you have the hardware.
