Frogman
- Joined
- Jul 11, 2005
- Messages
- 6,914
- Reaction score
- 1
I've ehausted every search vord variable I can think of....
A couple fo weeks ago, I noticed that I could not turn the radiator fan on via my Star Tester. Low Speed OR high Speed. If I run the engine and turn the AC on, the fan runs on High speed, as it should.
So, I tool out the Fan, and tested it with a test jumper from the battery. Fan works fine. So now, I am suspecting the fan module, but I can't find where this thing is.
Alldatadiy tells me:
There is no picture of it, and I can see several little "modules" in front of the radiator, when I pull the plastic pieces off.
The FORD manual CD's are useless, as you cannot do a "CD wide" search for a subject. All the module listings I found do not come close to the fan control module.
So, does anyone have a better description? Maybe a pic? Thanks a bunch.
Alldata said:The Variable Load Control Module is located at the lower front center of the engine compartment.
