2005 LS Sport V8, >90,000mi. Owned car since 2008. Once weather began warming up, I noticed fan noise would get very loud after normal engine temp and AC on. Sounds like very loud howling sound as if fan too fast or insufficient air flow. Removed debris from front of radiator and pressure washed as much as possible w/o removing radiator. Changed top plastic rad hose connector (due to pin hole leak), fluid, and purged air. No grinding/bearing sound. Cools properly and recurrance of loudest sound is less but still occurs. It's like top fan speed isn't regulated properly. Also tried to check fan blades for damage. Dealer did hose change and second fluid change.
Any ideas?
Any ideas?
