cooling problem
cobrapowered93
Rochester Hills
well, i was driving down the road and i heard something pouring out of my car all over the pavement. it didnt really get too warm while i was driving it home. got home, and if you were facing the front of the car, its pouring out of the front right, lower end of the motor. i know basics about this car so im not sure what it is. waterpump? its pouring out as fast as im pouring it in.
Water pump is front and center. If it was leaking there, you will see it leaking right there. The thermostat housing is on the right but not up against the engine and the way you're explaining it, it's not sounding too good. Possible head gasket. Could be as simple as the radiator hose.
would it still be running good if it was the head gasket? and the way it sounded was like something burst and it started pouring while i was driving.
Oil filter housing possibly (is this your right looking at the engine or sitting in the car? ;) )
Turn on your AC, and check and see if the fan is turning. If it is not, then the fan has gone bad, and you need another one. I just had this happen to me two weeks ago.
