There are a lot of great threads concerning cooling system overhaul, I'm a novice but have gleaned enough to try this myself. However, I do have a few questions.
2004 v8
1. Installing the larger water-outlet gasket 9Z-8590-AB - I've installed the gasket but can't get entire width of the gasket into the water-outlet slot. I'm thinking this is ok because when I install the thermostat housing it will adjust and make the seal. Is this correct or should the entire width fit into the slot and install flush?
2. O-ring part 9Z-8590-BA - I initially purchased this for the water-outlet but it appeared incorrect once I saw the original. Can someone tell me what this o-ring is used for?
3. Coolant Filling - I'm thinking about filling the coolant with the front end still jack-up to help air escape the system. Will this help or is it a bad idea?
4. Bleeding - With the bleeder screw opened a few turns coolant sprays out and its hard for me to tell if I have a steady stream of coolant or if air is still escaping. When opening bleeder valve should I remove the valve screw completely?
5. Bleeding - When bleeding at idle for 5 minutes instructions are "add coolant to the degas bottle as needed to maintain the cold fill MAX" but the degas cap was installed prior to this step. I understand the obvious is to open the cap if I need to add coolant but is it o.k not to reinstall prior and just install when the 5 minutes at idle is over?
2004 v8
