cooling
Markviiiedrea
Speed Bump
Bloomington, MN
replaced my water pump, thermostat, coolent and flushed the whole system for 20 min. still running warm, not as high as before but it still gets up to the "o" on normal. any ideas what else it could be? i know the gauge is right when i open the hood alot of heat is comming off of the engine.
i get up above R sometimes, I don't worry about that - i don't think you should be too worried about O, especially in florida.
I replaced my radiator, it had 120,000 miles on it. It brought the temp down one full letter plus.
Would installing a tranny cooler achieve the same result, since it is taking pressure off the radiator?
MarkVIIIedrea, run a 2003 Cobra radiator. Twice as thick as stock and an all aluminum structure. ModPWR, Jeremi, is using it along with a few others. Fit's almost flush, we all know a LITTLE modin' is needed in these cars. I will be putting one in , in a month or so. Along with a nice flush fit tranny cooler.
I'm usually in the middle of R - M.
New radiator, trans cooler, and 180 Tstat on the way.
It's maintence time and the list continues... Like always.
thanxs, if it is not to much i will get the cobra, but if it is i can get a mark one for 125.00 what exacilly do you have to mod to get the cobra to fit?
called max on the prices, 165 for a stock mark one and i think he said 225 for an 03 cobra, i can pick one up for 125 here in town.
for starter's im going to pull the OEM one and clean it and try that if it dont work ill get a new one, thanxs for the help guys
