Lincoln_Lover
Hi. Newbie to group. I got a major restoration project could use some suggestions.
1986 Mark VII Bill Blass
_____________________________________
Issue:
Replacing Engine Control Module
When I got it out, unplugged, found the pins on the OEM had corrosion. Can't see well enough into the harness plug to determine its condition.
Anyone encounter this and what worked for you? I'm wondering if I soak the plug holes in brake cleaner or some other solvent, if they would clean them out and work effectively.
Can't determine what has caused the corrosion.
Issue:
