Cowl to Windshield Seal Part# Who Sells it?
nghtshd88
New Jersey
The seal between the cowl and glass pulled off causing a leak onto the engine. Tried pacthing it, didnt work. Who sells this? I think I found it on rock auto but it says its for the top.
Also a part # for the clips?
Are you sure the issue is between the glass and the cowl? The problem with water hitting the engine is usually between the cowl and the wiper shaft areas.
Fordpartsgiant has the seals joeger mentioned between wiper arm and cowl. And the round clips (push pin style that secure the cowl to the stut bar and a-pillar plastic.
Foam seal: 5W4Z-54021A46-A
Round clips: W705956-S300
I am not sure on the strip seal that runs along the top of the cowl and glass, but am also looking for a new one for my LS. will be watching this thread.
FWIW - My cowl was bowed a bit, so I was going to purchase new clips (the metal ones underneath that secure the cowl the the tabs below the glass). Turns out my alignment of the cowl was affecting how those clips were seating, and adjusting it a bit fixed the bow. I had to finessed the teeth on each clip a bit to get them to snap securely. But after enough shifting, pressing, etc I was able to get everything in and aligned.
Hope this helps!
Thats always #1 this time it pulled off and is leaking as well. I tried fixing it with clear silicone but didn't dry. Maybe some gasket maker if I cant find one asap.. dont need my new coils getting soaked.
Even where the spray nozzles pop in it was leaking, besides the trunk which I fixed. Waiting for the sunroof next.
Round clips: W705956-S300 50 clips for $12 http://www.ebay.com/itm/like/171707291842?lpid=82&chn=ps&ul_noapp=true
I cannot find the seal anywhere, looks like a used cowl is the only solution.
