I replaced the clockspring on my 00' v6. Horn works again, radio (volume, mute, etc...) works, but the cruise control buttons are still unresponsive. The cruise control light does not illuminate to show it's engaged after I press the on and set button going 40+ mph. I've verified that the cable moves freely at the TB along with all the vacuum hoses. In other words, no indicator and no cruise. I've done research on here but I only see problems when the cruise control light is on but does not hold speed, or if the cruise control fails to illuminate/work it's due to an old clock spring. No one on here seems to have the issue that I have hence the reason why I'm asking on here now. I had a code for a brake switch circuit input fault circuit B, but it went away before I put in the new clockspring and still has not came back.
I can do some more troubleshooting of my own, but I have a few questions to ask:
1) If a bad servo, would the light still illuminate?
2) If there is a fuse for the servo, where would it be located?
3) During research, I saw a member post there was a TSB for the steering wheel control buttons. Does that apply to my specific year LS?
Just asking for clarification. Thanks for your help.
Sincerely,
Fudge12
Sincerely,
Fudge12
