Custom sub box Help
free139stylz
Maryland
Hey motts if ya read this I would like to know if you have any pointers to give me before I try to build my first custom box for the trunk. What type of materials should I use??
Use 3/4" mdf (medium density fiberboard). Make a cardboard mock up. Make sure the box volume is within the recommended specs in the info that came with the subs. Take your time, and will turn out pretty good.
Seal the box with silicone or liquid nails, and use 1.5" screws.
also use fiberglass and resin to seal the box all the way up. MDF still leaks air through the wood it's self. that's why it is called "medium density" fiberboard.
This is really not necessary unless you just want a fiberglass box.
ohh maybe my question was I bit wrong I already have a real box but im just building a custom box around it in my trunk so it looks good and maybe cover it with suede or somthing like that...
