smegun
"damage may occur to the coolant system If not properly bled" …. after buying the vehicle pulling in from my test drive the gas bottle had broke leaving nice green coolant all over the underside of the vehicle ... I had to pick up the vehicle the next day the dealer told me it was a 100 bucks plus parts and a common issue ... after doing odds and ends and flushing the system trying to solve the DCCV valve hose tar and calk noticed there are other anomalies from the system like bubbling coolant even after a short idle on a restore of fluids you have to let it rest and purge a few times then it settles but what other damage can occur from a bad bleed.... my cam tensioner job has turned into what appears to be a steam bath but I don't see the words to describe 4 quarts of beer the dummy temperature gage and why the purge valve is now dry.... if I use the shuttle valve only two quarts comes out the purge is just relief for the system it was my fear that the thermostat doesn't know steams
