Daytime Running Lights
AspDotNetGuy
Canada
Do the 2003 and 2004 Navigators have Daytime running lights?
I am looking at importing one into canada and that is a requirement :D
Not srue about all 04
I can t finda ny mention of daytime running light for an 04 here is what I found:
Safety
Driver and Passenger Airbag
Head Airbags: Front And Rear Head Airbags
ABS: 4-Wheel ABS
Depowered Airbag Switch
Mirrors: Signal Mirrors
Brakes: Front And Rear Ventilated Disc
Brake Assist: Braking Assist
Safety Locks: Child Safety Locks
Seat Anchors: Child Seat Anchors
Headlights Auto Delay: Auto Delay Off
Headlights Dusksensor: Dusk Sensing
Fog Lights: Front Fog/Driving Lights
Parking Assistance: Rear Parking Sensors
Engine Immobilizer
Turning Circle: 40.40
Safety
ABS: 4-Wheel ABS
Engine Immobilizer
Umm do you have navigator? Can you tell me if your lights turn on automatically?
place a piece of tape over sensor on dash then put them on auto it will trick to sensor to think is night time all day long!!!1
I realize this response comes a little late but for what it's worth...
Asp I recently imported an 05 Aviator into Canada and it didn't have DRL's. Whether a model has this option can vary from state to state and many confuse DRL's with the Autolamp dusk sensing functon mentioned above. Canadian Tire offers a DRL kit for about $25.00 with very little modification.
All it is is a relay system. Positive and negative wires are hooked to the battery, and your choice of high beam, low beam, fogs, parking, or any combination can be activated by using a coupler clip the connect it. Then another wiree is simply wrapped around one of the spark plug wires repeatedly to detect an electric current, signalling the unit to activate whenever the engine is running.
Fog lights are easiest to access and hook up as the wires are readily exposed underneath the front bumper and the guy doing my Federal Inspection at Candian Tire didn't seem to have a problem with those being the DRL's.
