ghfun
I have 2002 LS and intermittaltly the A/C will start blowing warm to hot air on either the drivers or passengers side. I have been told it sounds like the DCCV valve but may be something else. After the car has sat on a warm day, the A/C always starts up normally, sometimes after 10 minutes or so out of the blue one side will start blowing warm air. If I run the temp up to 90 then all the way back to 60 it will clear the problem for some unknown period of time. Recently on a 20 minute drive I had to do this about 4 times. Other times it will funciton properly for much longer. It seems to manfunction after some cooling in the cabin has occured. In every instance if I make a short run, stop in a convenience store for example, it will malfunction shortly after starting back up.
Can anyone help me with some more info or cost or home techniques for evaluation of the problem and repair?
Thanks so much, ghfun@aol.com
