DCCV electrical connector
Blueberryyum02
Griffen
Was wondering if any can get their hands on this connector it's the one that sit near the a/c accumulator on the top left attached to the fan shroud. I have two wires that broke off which is the controls for the DCCV, so I have full heat on the passenger vents. Or is there a way I could retread the connector.
That's where im stuck at the few yards that have a ls in my area hold cable and connectors are missing.
What year is your car that needs a connector? Never mind. I thought that you could get one on rock auto but I don't see that connector/pigtail assembly available there.
I used an 01 connector from a junkyard on my 03...so 1st and 2nd gens are the same
I just tapped into the wires on the opposite end, and called it a day. I'll get around to fixing it right sooner or later. Still chasing this loud fan that's rpm depended only with the a/c running. At idle you can't hear it but when you give it gas you hear it.
... Still chasing this loud fan that's rpm depended only with the a/c running. ...
Either it's working like it is supposed to, or you have overcharged (too much refrigerant) the AC system. The PCM controls the fan to keep the engine temperature from going too high and/or the AC system high side pressure from going too high.
Ok thanks joe money been a little tight so I haven't had time to take it and get the a/c looked at.
But on the bright side I've just about replace all clamps on the hoses, and clean the heck out of the radiator, found some hornets living in there, and a mass grave sight of every bug from Georgia to Chicago and back.
