DDM HIDs
jake624
Westland
I installed DDM HIDs 55w headlights and all went fine. I installed DDM HIDs 35w for foglights and I could not get the passenger side to fire. I checked the bulb and the ballast and they both worked fine on the driver side, neither worked on the passenger side. I put in my LED bulb and a standard bulb in the passenger side and they both worked fine. Anyone have any ideas?
My guess is he needed to swap the wires in the harness on the one side. I had to do that to the 35W kit I put in for my fogs. One side was wired fine, and the other had to be flipped for it to work.
Exactly. Odd this was only 1 of the 2 ballasts worked on the left side, even when the wiring was swapped. Oh well, it works and that's what matters.
