lxman1
Hello,
newbee to the forum, but not to Lincolns. I am currently trying to repair my father in-laws 1996 Lincoln Conti.
The air suspension is dead. The compressor runs fine if I run 12V to it from the battery, so it's not that. It shows air susp. OK in the diagnostics, but does not work. I even found and swapped out the suspension module in the trunk (that looks like an ECM). This seemed to get rid of the ABS and Traction control lights that were on.
It's like the system is getting no power. I have checked every fuse and relay that I know of both under the dash and under the hood. All are good.
Any ideas on where the lost power has gone?
I appreciate any help that you can give. I am buying a 96 Ford shop manual for this car, but it will be next week before it gets here.
Thanks,
Jimmy
Thanks,
Jimmy
