Dead Battery
mikejohnson
hull
Hey guys I have a 1990 lincoln mark Vll only 39,000 miles. I had a dead batery so, I just bought a new one. Worked fine for a few days. Since it's my fun car it sat for about 3 days dead battery again...recharged died again. I had the alternator tested it was fine. Unless I unhook battery takes 2-3 days to kill battery. Everything is still factory in car....any ideas??
Check the voltage regulator if you are sure that the battery and alternator are good. Then check your draw from the battery with a multi-meter with everything off. If you have an abnormally high draw on the battery you can start narrowing it down by checking the draw with certain electrics removed.
