stumpy
For the 2nd Gen dealer installed remote start, does anyone know how to adjust the cranking time?
I have the same issue on my 02. Unless it was run withing the last 10 minutes or so, it takes two attempts. Based on sound, the engine is just half a second from catching, too.
Unfortunately, it's tucked up behind the driver's knee board sheetmetal, ziptied and taped up like a mofo, so I can't read. I thought it was a DEI unit, but later found out I was looking at a bank of relays for the remote start.
chances are if it is using a DEI relay pack, then it is also a DEI RS system
bump for anyone who did this?
grab or take a picture of everything/number you can... some have tons of different numbers on them, some only have one or less.What kind of model number should I find? I only ask because these things tend to have multiple numbers printed on them.
a lot of times, the bypass module can be in the same area as the main brain with just a couple of wires and maybe an antenna to/around the ignition switch.Presumably, there's also a transponder bypass mounted next to the key hole behind the accent trim panel
I didn't know they had a module as well. I had only seen what looked like a glass transponder pill half covered by shrink tube with wires coming out.
bump for anyone who adjusted dealer remote start crank time
Ever had that happen?
Changing the crank time is not an option. Re-learning the tach is an option. I will try this when the temps warm up.
I know my LS has a sticker and... hold on, I'm an idiot. THAT sticker DOES say it is specifically a DEI RS system, now that I think of it... moving on, the sticker says "if the battery is reconnected, the RS may try to start the car"
