developing problems
Rope
Wichita
hay JC1994 how is your shock mount is holding up, mine didn't last long so I did what you did I went and bought a set of monroe shocks and replace them that was a while back and they are holding up, now my rear air bags are leaking on me, I order a set from Strutmasters last friday and got them to day, and tomorrow I will be replacing them along with my sway bar which is broken.
Some problem start to developed with my car. When I turn on my AC, the air come out through the defrost no matter what I do, my car pings when I step on the throttle, that's a few thing I will be looking at, so maybe some of you guys can give me some short cut on how to fix these problems, I got a week off, so lots of time on my hand.
the ac probibly a vacume leak somewhere and the pinging what kind of gas you use if you use reg try switching to premium good luck
I use nothing but premium but I don't know if my girl friend put any thing different in, I tell her to use premium all the time or mayby I got bad gas, I get my gas from QuickTrip.
O, I fail to mention, at first start up after the engine cool down like say the next day, when I step on the throttle my car hesitate before moving forward, I notice it all after I went and had my oil change.
that connection, and the one that runs from there to the inner fender. There is a vacumn canister in there that has a habit of cracking. That could explain your hesitation also. (vacumn leak)
