Died
lippytwo
Galena
I have an 89 towncar.Was going down the road it died wouldnt start for about 20 min.Then it did.Got home tool it to mechanic new starter new cables new battery........Ok for monthe then it died again chugged a little like it was out of gas would not start back up this time........female please help
:soapbox:
Sounds like fuel pump problem when hot, or ignition module shutting
down when hot.
Hi lippytwo
Sounds like the classic symptoms of the TFI module or PIP going bad.
The TFI module is on the side of the distributor and the PIP is insied the distributor, I would recommend Ford replacements only.
Next time the car dies immediately after it dies check for a spark (using an old spark plug).
Regards
Dereck
First off :W to :V . You found the right place for support! Looks like you are getting good advice already.
Isn't this site great!! You'll get great support and help from all members here. Lots of Lincoln Experience! :Beer
