DISASTERS TEND TO HAPPEN IN THREES
8-10-2006 I carelessly damaged my Mark II as I pulled it out of the garage to go to a Press Preview of the Willistead Classic. It's parked on a four post lift, in the down position during the summer as I park the Porsche on top for winter storage.
I pulled too far over and took off the Mark II emblem and left a very nasty set of gouges in the paint with the lift's support cable. I went to the Press Preview anyway.
I loaded up the Porsche and had a friend, who moves cars professionally, tie it down for me for transport. I had positioned the car so that it lent some noticeable tongue weight.
Friday 8-11-2006
My employees and I spruced up the work truck for travel. I had just had every system service and checked on the truck. I wanted an uneventful ride. I drove home and packed and loaded the truck for a fun weekend at a Concours that we helped develop.
We shortly encountered some construction that required some lane changes and the trailer handled pretty well. We made it about 30 miles when disater struck. I had been traveling in the left lane of a freeway and exited on a continuation of M-14. This is one of those left-entrance ramps and I wanted to end up in the right lane. I had a clear shot at a lange change and moved over at about 45 miles an hour. The road was crowned and slightly curved.
I felt the truck start to pull and I knew I had a problem. The trailer started to fishtail quite forcefully. I had read, and I had pacticed, using the brake hand controller in the event of a bad sway to drag the tow vehicle down in speed and straighten out the sway. I used the hand controller and it had no effect the first time. Apparently I didn't leave it on long enough as it has to build up pressure in 24 pistons. The second time I tried I got almost immediate results and the truck straightened out as I was headed for the concrete median wall.
By this time the trailer had done about 4 wags. I pulled away from the median as the 4th wag smacked the driver's side tail of the trailer against the median. That seemed to interrupt the pending catastrophy and shoot us off across the sholder and two lanes of the e-way. I was now headed for what I perceive to be a ravine. My wife remembers it as a large ditch. I was now somewhat in control. At least I was headed in the same direction as the rest of the traffic.
The ravine was fitted with a guardrail that probably saved our lives. Unfortunately, that impact tore the Porsche loose from its mountings and slammed it into the passenge side wall and rear door of the trailer.
The only thing that kept the Porsche from crashing ino the lounge was the spare tire for the trailer. It wedged the front tire of the Porsche up against the winch.
The Porsches's pretty messed up, but repairable.
The trailer suffered some structural damage, but also can be repaired. I'll have to find a donor trailer.
I believe what happen had to do with the newly installed load distributing and sway control hitch. One of the torsion bars dropped out of its socket and hit the pavement as did the chain cinch it was attached to.
One of the torsion bars, the one that hit the pavement, shows signs that it worked its way out of its socket as its wear pattern shows.
I believe what happened is that the torsion bar fell out of its socket as we crested the crown of the road. This is when there would be no tension on the bar. The hitch is fitted with a pull pin that must have worked its way out or rolled over to reveal its tapered side. The conditions must have been just right and allow the torsion bar to drop out.
The torque that the trailer went through with one of two torsion bars exerting torque on the frame was amazing. The 2" solid steel hitch insert bent to about a 20° angle. It looked like tubing that had bent. Very scary.
While this may have been an unfortunate couple of days I believe I am fortunate to be amongst the living.
BTW, I believe we have chosen the name for our trailer. It will be forever known as "The Phoenix". Appropriate on so many levels.
Friday 8-11-2006
