distance to empty
baldguy
skykomish
every time (99%) i start my 88 lsc the dte reads 0 no matter how much gas is in the tank. i've gotten in the habit of always hitting the clock button to disregard the warning. every now and then after driving i hit the dte button and actually get a reading that i would believe.
is there a remedy for this problem?
I have ran the diagnostic for the whole info center but it was no help.
You might try disconnecting the battery. That will reboot / reset the Message Center computer.
and if the message center is working properly... ?
A malfunctioning fuel gauge (in the tank) i suppose.. maybe a corroded wire connector somewhere is intermittently being disconnected.
( But I don't know if a disconnected fuel gauge will read the tank as empty or full.)
Empty.. zero miles.. Not 15.. not 42 miles. That "zero" may be a clue that points to some critical fuel-gauge fault, like a disconnection.
I was getting an annoying chime at every startup, but it was DEST = 0, not DTE. I accidentally fixed it by fooling with the buttons.
Common Problem
This is a common issue with these cars. Mine does it too. Either it tells you zero or it gives you an accurate reading. I actually think there was a ford TSB (Technical Service Bulletin) pertaining to this very issue. Try resetting your average speed once in a while, it seems to work for me. I started doing this because i assume this would be one of the parameters the computer uses to calculate DTE. Try resetting it every time you fill up and see what happens.
Electrical Issue
Start with a new battery and new voltage regulator and replace the ignition switch (see my signature). Once these three things are done, then you can troubleshoot the problem without chasing your tail.
