Does This Come with SLIDER Pins? ASAP...
PioneerCrazed
Orlando
Hi guys, trying to fix the Mark again and my rear brake caliper bracket has the lower slider pin seized up big time... It caused the inboard pad to wear out to nothing and start to gouge the freakin rotor...
Anyways, I'm looking at this caliper bracket and rockauto.com are the only ones with it in stock; but Advance + others do sell it factory direct.
http://www.rockauto.com/catalog/x,carcode,1188525,parttype,1714
I need to know if it comes with the slider pins? Anyone know, or where I could get new slider pins?
Thanks
YOU FREAKIN ROCK!!!!
Ordering that right now, Would've sucked to wait and get just the brackets...
Make sure to lube the caliper pins with dielectric grease. Yeah, I know, the tune-up grease is the same stuff Ford uses on an enclosed pin with a boot.
