Dohc 5.4
cf99gt
waco
anybody swapped a DOHC 5.4 in a mark 8 out of a navigator ? i know there is a company that makes adapter plates to use the 4.6 intake manifold and they bolt up to the same motor and transmission mounts. reason im looking into this is because id like to make as much power as i can N/A and then spray it at the track. any info at all will be greatly appreciated
no no, forget that. lol. id much rather have a DOHC 4.6 than a SOHC 5.4
With the front spindle location and the added weight of the iron block 5.4 vs aluminum 4.6, traction would be a larger problem and not ONLY because of power. I don't see all that work being feasable on any level unless you go all out and move the firewall back. It's not hard to mod the 4.6.
