door panels 98 lsc
papaSMURF
Bloomington in, Northside Chicago
ok so i had some component speakers installed in the fron and rear of my car, but i need to switch them around a bit (one set is going in the trunk) how does one go about removing the door panel WITHOUT breaking clips.
mustangs and others are easy, but i cant find the screw hole covers or anything to get the panel off..
there is a screw behind the courtesy lamp, and a screw behind a small cover that's on the underside of the door handle. unscrew those two, then with a panel removal tool unclip the plastic trim ring from around the chrome handle, and then lift up the whole panel, comes right off.
