door panels
Jeffintampa
Tampa ish
Guys I just bought a new passenger inside door panel from a guy who was parting out a car. When it got here It did not have the tweeter cover in the plastic smooth part in it. I am going to list it on ebay and need to know if it did not because it was not a lsc? Or did certain years or models not have that small speaker
Gen I's without the JBL upgrade do not have a tweeter speaker, with JBL they do. My 94 had no tweeter while my 96 did.
i know what you are saying jeff, your lsc has the jbl stereo system, the panel you got was from a mark with premium sound, jbl cars have 8 speakers, premium sound only have 4, the panel you bought is from a premium sound mark so it has no tweeter grill on the top of the door panel, that long plastic trim can be removed from your door panel, and swapped onto the new door panel, the tweeter hole is on the new panel, every door panel had a hole for a tweeter, some just didnt come with tweeters. its a paint to swap the trim because the nuts are burried behind the yellow foam on the back of the door panel, you have to know where to cut a section of the foam out, i know where!! you'll probably make a mess trying to find them though!
As always thanks Jamie, and tips or measurement from the back going to the front? for the nuts?
Jamie is the bomb.
Made your second set of ribs yet?
needle nose pliers and patience. and yes i made ribs again the other night and they were even better than the first batch yum yummmmm!
I used the tubular pipe wrench 6 mm - the outer side of the pipe matches perfectly, and the plastic stand in the middle fits into the 6 mm. Like this one on the pic.
